"Vertical arrangement Property" does not seem to work for Y scale marker
It appears that the "Yscale- Marker-Vertical arrangement property" does not work. Returns an error " you may only set vertical arrangement on a label, caption or free label". Quite understood, but then why is it there in the first place for markers when it only works for labels, captions or free label??
[BADGE NAME]
(2,897 Views)
Hi blessedk,
it's a (more generic) text property, which is available for all text objects. But you can only use that property for certain objects, as is written in the LabVIEW help and error message…
(The LabVIEW help features a full chapter on properties and methods!)
(2,891 Views)
Yes agreed. I just don't think there is any point having that where it does not apply/ work
[BADGE NAME]
(2,886 Views)
