"read spreadsheet file" & "excel get data" get different results (bug?)
I want to get data from .csv file, but find a problem & hope someone can tell me the reason.
There are some "double quotation marks" in csv file. for example:
Castlenet;"CastlenetSAS603";"2N38024000001";"
I read the csv file with "read speadsheet file" function  but get an abnormal result as below:
"Castlenet;""CastlenetSAS603"";""2N38024000001"";""
It seems that every "double quotation marks" appear twice time
But another function " excel get data"  indicates the right data as below
I try them on different OS (XP or Win7) and different labview version(8.5,8.6); but get the same result
read speadsheet file can't indicates the right data, does anyone can help on this?
(2,521 Views)
Accepted by topic author DNF小号
You would have to do a search and replace to eliminate the quote marks. I believe the quotes in a csv file are allowed in a proposed standard but the LabVIEW implementation does not fully comply with the proposal.
There is an idea exchange post on this that I can't find right now.
(2,493 Views)
