"save" array
Hello!
I have a VI, where i "manipulate" an array in two for-loop...
It calculate the array element well, but it didn't "save" it... can somebody tell me, how can i solve it?
(i attach two different bad solution...)
thanks!
Kolos
Message 1 of 8
(5,006 Views)
I dont have lv 8.2. Can you post a screen shot?
Message 2 of 8
(4,994 Views)
Solution1:forum.JPGű
Message 3 of 8
(4,989 Views)
The results (name:Numeric) are good, just it didn't save them... 😞
Message 4 of 8
(4,988 Views)
Hello!
Fix:
Message 5 of 8
(4,981 Views)
Accepted by topic author Kolos
Wiring is a bit "tough". I dont see any point in using a time delay of "0" ms. Use a shift register to save your values.
Message 6 of 8
(4,978 Views)
a-a i think, you wrong...
the first array size here: 10,10 The size of it is 2... but i need to make it 10 time..
Message 7 of 8
(4,972 Views)
The time delay is good, if i wan't to check, if the "part results" are correct...
I never used shift register...I try it...
Thanks..
Message 8 of 8
(4,969 Views)
