"string" missing in function pannel
  I'm developping a labview code for serial communication,  but when i right click in the controle pannel i do not  found "string" in "functions" pannel
  I'm working with LV 2013, this do not happen in labview 2012
 Have any body and idea about why "string" is missing.
 cheers,
SASA
Message 1 of 8
(3,814 Views)
Hey,
are all palettes show in the function palette?
Step 1. pin the palette to the blockdiagramm -> click on customize in the upper left corner -> change visible palettes -> select all
if this doesn't help...
Step 2. Tools -> Advanced -> Edit palette set -> relink the palette -> insert Subpalette -> link to existing -> ...\LabVIEW Data\2013(32-bit)\Palettes\menus\Categories\Programming\string.mnu
CMW
Message 2 of 8
(3,807 Views)
  Thank you very much for your answer,
  but i did not find the "relink the palette -> insert Subpalette -> link to existing " path
   when i click on tool->advanced-> edit palette set i find a winfow names "Edit Controls and Functions palette set" where i did not found "relink the palette -> insert Subpalette -> link to existing "
SASA
Message 3 of 8
(3,780 Views)
Oh ok I see, ...
Tools -> Advanced -> Edit palette set -> rightclick into an empty space on the palette-> insert -> Subpalette -> link to existing -> ...\LabVIEW Data\2013(32-bit)\Palettes\menus\Categories\Programming\string.mnu
Message 4 of 8
(3,763 Views)
Ok, now i found the "link to an existing palet file" but i do not find the file?
can i download it? 'may be)
Cheers,
SASA
Message 5 of 8
(3,756 Views)
Accepted by SASA1
check also in this path:
C:\Program Files (x86)\National Instruments\LabVIEW 2013\menus\Categories\Programming
Message 6 of 8
(3,749 Views)
it works now, but only in block diagram,  in control panl it does not appear.
SASA
Message 7 of 8
(3,719 Views)
Functions are only on the Block diagram. Controls and indicators go only on the Front Panel.
Take the time to go through the getting started tutorial.
Message 8 of 8
(3,679 Views)
