"vi analyzer" missing
I was at recent Labview User Group meeting where they talked about using the VI Analyzer to improve one's programs.  When I ran my Labview 8.5, I couldn't find it in the menu under "Tools".  I then shut down my Labview and reinstalled Vi Analyzer 1.1 from my toolkit CD.  Unfortunately, it still isn't listed in my menu when I ran Labview again.  Is there an additional step that I'm missing to use this tool?
Message 1 of 15
(4,841 Views)
It is part of the Productivity Toolkit, which is available with the Developer Suite, unless purchased seperately.
Which version (Pro, Full, Dev Suite) do you have?
See list of toolkit:
Productivity Toolkits Included
  • Report Generation Tools for MS Word and Excel
  • Database Connectivity Tools
  • Statistical and Process Control (SPC) Tools
  • Internet Connectivity Tools (FTP, E-mail, and CGI)
  • PID Control Tools 1
  • Fuzzy Logic Tools
  • Advanced Signal Processing Tools
  • Digital Filter Design Tools
  • Linear and Nonlinear Control System Tools
  • State Diagram Tools
  • VI Analyzer
Message 2 of 15
(4,829 Views)
I have the Developer Suite package with all the goodies.
Message 3 of 15
(4,833 Views)
I too have the developers suite. In 8.5 the VI Analyzer is missing. I do have it in 8.2. I also have versions 8.0 and 7.1 on the same computer. I know one fix for this is to uninstall the toolkits and reinstall them. That will make them available in 8.5 but not in 8.2. I am looking for a document that describes how to make them available in all versions but am having problems finding it on this site. I do know it used to be available because I used it in the past. I'll keep looking and post it if I find it.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 4 of 15
(4,815 Views)
I would call NI support.  It could be something as simple as the activation (serial no?)..
If you did a full install, it should be there..
Edited Portion:
I just read GovBob's reply...  Sounds like there might be a bug...
Message Edited by JoeLabView on 09-13-2007 12:57 PM
Message 5 of 15
(4,817 Views)
Here is a link that might help. I used it  for 8.0 but I am not sure it is still valid for 8.5. Luckily I''ve got an NI rep coming to visit late this afternoon and I'll discuss it with him.
http://digital.ni.com/public.nsf/allkb/58BE852CB35237C786256A290079DF39
Message 6 of 15
(4,808 Views)
I found this comment in the readme file of the toolkit CD.
If you are using the VI Analyzer Toolkit 1.1 with LabVIEW 8.5.x, install the patch located on ni.com Drivers and Updates
I went looking for the patch and found this dated from 2004 and refering to LV 7.1. The question is if it is still valid for LV 8.5?
http://joule.ni.com/nidu/cds/view/p/id/676/lang/en
Message 7 of 15
(4,796 Views)
Thanks for the info the in the above link was one that went to this NI link which works here as well, but all in all this is costing me over 1/2 hour per machine that could have been taken care of in the install itself. Thanks again NI for letting me know you think my time is so valueless.
Message 8 of 15
(4,764 Views)
Sorry for the inconvenience. We know your time is valuable and a graceful (:)) solution to this problem is actively being pursued.
Roy
Message Edited by Roy F on 09-19-2007 02:22 PM
Message 9 of 15
(4,688 Views)
I received this answer from NI support, applied it and now I have the Vi Analyzer tool:
"You can install VI Analyzer 1.1 to LabVIEW 8.5 only if it has not been installed for a previous version of LabVIEW on the machine.  To install the VI Analyzer for LabVIEW 8.5, you will need to uninstall the toolkit for 8.5, then install it to the LabVIEW 8.5 directory.  This step is important, since the installer will default to the 8.2 directory and you will have to choose to change the directory to the LabVIEW 8.5 directory to use the Tools >> VI Analyzer tools.  If you are only using the VIs, then you can copy the analyzer folder from the LabVIEW 8.2 directory >> vi.lib >> addons directory.  This will allow you to use the VIs in 8.5, though you will need to uninstall and reinstall to use the analyze VIs or Show Results Windows tools from the tools menu.  "
Message Edited by mysticfree on 09-19-2007 02:23 PM
Message 10 of 15
(4,676 Views)
