radians to degrees not working like my calculator
On my graphing Calculator sin(52)= 0.7880107536 (its on DEG)
The same with my scientific calc. I dont know why its not working
when my they are on RAD it shows the exact same as labview shows
but when i try to make labview use Degreese it gives the wrong answer
(6,565 Views)
How are you "making LabVIEW use degrees"? Please show us some code! (I suspect you are trying to use units)
(6,564 Views)
If you want to use degrees you'll need to convert to radians by deg*2PI/360, the Convert Unit  seems to do the job fine.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,545 Views)
here is the code, i thought i included it earlyer
Rad to Deg
(6,516 Views)
Accepted by tvanprooyen
You are feeding a 52 (radians!) to the sine function and converting the output. That makes no sense!
You need to convert the angle to radians before the sine functions.
(6,510 Views)
I see exactly what you mean, I dont know how i missed it, all the answers are correct, thank you so much. Here is what i did...
Degreese to Rad
(6,494 Views)
