radians to degrees not working like my calculator
On my graphing Calculator sin(52)= 0.7880107536 (its on DEG)
The same with my scientific calc. I dont know why its not working
when my they are on RAD it shows the exact same as labview shows
but when i try to make labview use Degreese it gives the wrong answer
(6,544 Views)
How are you "making LabVIEW use degrees"? Please show us some code! (I suspect you are trying to use units)
(6,543 Views)
If you want to use degrees you'll need to convert to radians by deg*2PI/360, the Convert Unit  seems to do the job fine.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(6,524 Views)
here is the code, i thought i included it earlyer
Rad to Deg
(6,495 Views)
Accepted by topic author tvanprooyen
You are feeding a 52 (radians!) to the sine function and converting the output. That makes no sense!
You need to convert the angle to radians before the sine functions.
(6,489 Views)
I see exactly what you mean, I dont know how i missed it, all the answers are correct, thank you so much. Here is what i did...
Degreese to Rad
(6,473 Views)
