random Number
Hi
i want to build application to get random number between  200 to 250
how can i do that in labview
nots i have labview 9
thanks
(3,456 Views)
The random number generator in the Numeric palette generates a number between 0 and 1.  Read the help for details.  Take that number and do some math to get what you want.
Lynn
(3,453 Views)
Accepted by Elyan_wisam
The random number function in LabVIEW generates a number between 0 and 1.  Multiply it by 50 and then add 200 to it.  If you need only integers, then convert it to an integer at the end.
Randall Pursley
(3,452 Views)
Note that the distribution may not be even if you do this.
See this LAVA post regarding the development of the OpenG Random Number Within Range function.
(3,418 Views)
