random number with upper limit
Even if the numbers are less than 45, there is a non-zero chance that they will be equal. What is the purpose of this exercise? How do you run this?
Message 11 of 15
(1,371 Views)
Ben
Message 12 of 15
(1,369 Views)
Ok Ben ... this is the solution.
but, if i have other random Number...
who  to guarantee that not have  the same number thet the first?
Message 13 of 15
(1,365 Views)
You can generate other random numbers in a loop and exit the loop once it is different and keep the final number.
Message 14 of 15
(1,362 Views)
     I understand that he wanna 2 random number but with 1 always under 45.
Spanish: "Si tienes problemas expresando lo que quieres en ingles, hay una sección del foro exclusivamente en español que puedes utilizar"
Best Regards,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 15 of 15
(1,355 Views)
