randomized 20 trials for 6 digital channels
I want to randomize 6 digital outputs , 20 times but each channel must be switch on only 20 times and one channel must not be triggered twice in a row !
I know i have to use a for loop bu i dont know how to say to the software, just trigger them 20 times and stop it after.
Thanks for your reply
(2,462 Views)
I don't think you can generate a truely random sequence. It will just cost you a too large number of trials. I have calculated that you need about 1.25 x 10^9 assays before generating a single random sequence without any duplicate consecutive channel adress.
What you can do is to use a pseudo random sequence by associating four random sequences of 30 channel adresses, after checking that the last and first channels are different !
You can use the attached vi to generate your sequence. Try first with only few replicates (5-6...), otherwise you may think that the program is not working !..
Chilly Charly    (aka CC)
(2,454 Views)
Disregard my previous post : if the sequence is generated progressively, channel after channel, just checking that there is no immediate repeat, a solution is rapidly found.
The attached vi does the job.
Enjoy !
(2,431 Views)
