read and configure json file
I'm coming to you because I'm a bit stuck.
I want to read a json file and configure it.
I have 4 controls (passenger 1 to 4). The controls are true or false when doing the import picture to clipboard.
So I have my controls configured if the value is 0 (in the config file) the control (passenger) appears and if it's 1 the control is not possible.
I did it with an .ini file but I am asked to do it with a .json file.
I don't know json at all, I tried this but it doesn't work.
I don't know how to do the property node (visible, value) in this case with the keys and values.
Can you help me please?
Or give me some hints?
The json file does not supported here, so i enclose its screen capture
Thank you very much
(4,264 Views)
Accepted by Ngouda
It's good that you already have the JSONtext library. Just wire all controls to a cluster and input it into the 'To JSON text.vim". You'll get the correct JSON string.
(4,256 Views)
Hello Basjong53,
Thank you for your reply.
Can you save your example under the precious version please? I have Labview 2021 and where to send me the vi directly if you don't mind.
(4,197 Views)
@Ngouda wrote:
Hello Basjong53,
That image is a snippet, so after saving it you can drop it in your diagram.
(4,179 Views)
Hi ngouda,
please don't send PMs when you already received good answers!
What's wrong with the example snippet you got?
Use the label of those controls as key, then you can easily look up the corresponding control reference based on the keys loaded from JSON. Then just use a "visible" property node with the reference found for each key…
(4,150 Views)
