read file
Accepted by topic author divyakarthikeyanmit@rediffmail.com
I am glad that i understood the problem right,
The problem you were facing was because, there was no dependency between Write and Read VI's in your code, So you never know which VI could execute first (In your Case Read vi executed before Write VI most of the times), by connecting the error cluster from write VI to Read VI we gave dependency that Read vi will execute only after write VI has completed its execution.
Its LabVIEW fundamental as its a dataflow language.
Actually Divya i would suggest you to go through the Getting Started with LabVIEW document once before going ahead.
Even read write spreadsheet VI's will work similarly, you can also find examples for write and read files.
Krunal
Message 11 of 13
(1,008 Views)
if your previous question has been answerd can you please mark  Krunal K Patel thread as solution . So that in future people can easily find the solution rather reading the whole thread.
thank you
Regards
Message 12 of 13
(1,001 Views)
thanks a lot
Message 13 of 13
(997 Views)
