read from Spreadsheet File VI
Hello to everyone!
I want to read a spreadsheet file VI, wich contain many rows with this format:
0.475009,0.242797;
0.023044,0.522105;
0.735105,0.634358;
0.955100,0.982586;
etc..
The goal is to divide these rows into 2 array: the first one contains the left number:
0.475009
0.023044
0.735105
0.955100
while the right one contains the right number:
0.242797
0.522105
0.634358
0.982586
Someone can help me?
Thanks and
Best regards!
(4,707 Views)
Hi Davide,
do you think you can make your way starting from this snippet?
It's rather unusual to have a different delimiter to denote EOL. You should use a comma only between numbers and get rid of the semicolon at EOL!
(4,703 Views)
Hi GerdW.
The end of line delimiter is ;
with comma i separate two different measurements: the left numbers rapresent a current measure, while the right numbers a voltage measure.
I want to read my csv file, split the numbers into two different array, then plot the current and the voltage.
My start point is:
where all rows are like this:
i want to separate the left numbers and the right numbers into two array
Best regards
(4,694 Views)
Hi Davide,
1. You need to give the separator char between your numbers, not the EOL char: change your string constant from semicolon to comma!
2. From your description I still think the semicolon is useless as you (probably) have some real EOL chars in your text file (CR, LF, or combination of both)!
(4,690 Views)
3. And you should change the type of the "Read from Spreadsheet File"- VI to Dbl, then it should ignore the semicolon and gives back the datatype you need.
Greets, Dave
(4,678 Views)
Resolved!
Thanks a lot!
Best regards
(4,658 Views)
Hi Davide,
usually the OP also tells how a problem was solved, to help others experiencing the same (or very similar) problem…
(4,656 Views)
