read from spreadsheetfile
hi,
i read from a spreadsheetFile,i want to read each value ,but in my code i can read only the first value.how i can resolve this problem ?
i want to calculate the value  :  S=sum(sqrt(xi+yi)) where xi represent the value readed from xoffset.txt and yi represent the value readed from yoffset.txt  at iteration i
(3,697 Views)
Hi iman,
it seems you really should learn to use the context help. Some basic debugging techniques would be ok too.
Going through basic courses offered by NI would also be a good idea...
(3,668 Views)
Modified..
What you are reading is a 2D array and the data is in Row -0.Just need to index Row zero and take the values
(3,665 Views)
I didnt see the post by GerdW..Thats more simple
(3,660 Views)
but i want all the datas in all rows not only in the first row
(3,649 Views)
Hi iman,
your example files only contain one row of data...
Just use a FOR loop with autoindixeing inputs. It will automatically index of the rows of your 2D data.
Did I mention the basics courses offered by NI?
(3,645 Views)
yes please
(3,640 Views)
