read from text document to display into graph
 I want to change the output from 1D to 2D.
So I used Reshape array.
But why does the error say that it is of a different dimension than the graph? How do I solve it?
Message 11 of 13
(413 Views)
What is the need to change the dimension from 1D to 2D? any specific reason?
Did you check the output of Reshape array function by connecting an indicator before passing it to bundle function?
______________________________________________
Kudos are welcome
Message 12 of 13
(395 Views)
LHX,
Have you taken any LabVIEW tutorials?
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
You seem very insistent to using all the wrong tools for the job you want to do.  Maybe if you watched the tutorials you can get a better understanding of how the LabVIEW functions work and then start using the correct tools for the job.
Message 13 of 13
(391 Views)
