read from text file and plot in real time
Hi. My goal is to read some data from a text file that another program is coninually updating and plot this data in real time as the other program updates the data.
Right now I am still working on just reading the data from a text file and plotting it.  I have successfully read a line of data from a text file and placed it in a numberic array, but i am having problems plotting it all on the same graph.  The array I am using is 10 X1 with the first element being the time and the rest of the 9 are the variables i wish to plot vs. time.  I have been doing this with an xy plot, but I have only been able to plot each variable on its own plot individually.  I want them all on the same plot.  Also I would like all of the data to remain on the screen.
I have attached my VI and the text file.
Thanks.
Message Edited by jgkempen on 09-06-2007 04:52 PM
(3,045 Views)
With the XY graph, you will need to format your data so that you have arrays for your X values as well as the other 9 Y values.  From there, you can bundle them together, build an array of XY data, and plot as shown in the image below:
Craig D
Message Edited by Craig D on 09-10-2007 06:40 AM
(3,007 Views)
