A problem about property node
    Why this VI use property node before visa read?
(3,569 Views)
The 'Bytes at Port' property is read so that VISA Read knows how many bytes to get.
Albert
(3,566 Views)
Thank you, Albert.
Is property node absolutely necessarily? Visa read can get bytes itself. Are there many differences?
(3,562 Views)
Hi hengfo,
      It's not necessary to use "bytes at port", in fact, I don't trust it, it seems there can be some strange latency! (see threads below)
Just go ahead and wire the number of bytes you want to read to the Read  - but be ready for a timeout error if the bytes you request don't arrive within the VISA timeout period. Smiley Wink
See these threads:
http://forums.ni.com/ni/board/message?board.id=140&message.id=7839&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=111079&requireLogin=False
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,553 Views)
Thank you very much, tbd!
(3,535 Views)
