read png: transparancy doesnt work out very well
Im programatically loading PNG pictures and putting them in a picture box; however I see large differences when I programatically load a picture or just drag it to the front panel from windwos explorer; see attached picture.
I can change the transparancy for the loaded PNG, but making this very high makes the image alias badly; doesnt look smooth. When its low it has white edges.
Are their any other options?
The left is programatically loaded, the right is dragged from windows explorer; identical image.
I have attached the original png too
Felix
(3,113 Views)
There's a VI hidden in vi.lib that is used in some examples for handling transparency, you may want to give it a try and see if it helps. The VI is located @:
C:\Program Files\National Instruments\LabVIEW 2010\vi.lib\picture\picture.llb\Create Mask By Alpha.vi
I found when I was looking at the Traverse Tree and Set Custom Symbols.vi example, its in the Load Symbols.vi subVI of this example if you want to find it that way.
(3,086 Views)
Accepted by _Faust
You can try the code I posted here:
http://forums.ni.com/t5/LabVIEW/how-to-get-alpha-images-on-picture-box/m-p/1138513#M501588
The boxes are drawn to test the blending.
(3,071 Views)
Brilliant!!
(3,049 Views)
