read soundcard output???
hello,
is it possible to read data from the output of a soundcard (in labview)? I
would like to build a spectrum analyzer that monitors the soundcard's
output. any ideas?
klaus
(3,693 Views)
The only way that I know to do this is to actually take the output of
the card and route it into a data acquisition card, specifically a sound
and vibration card. You can then use the standard VIs is LabVIEW to
get and display the sound card output, as well as the frequency content.
Mark
In article <8tbvoq$mfu8q$1@fu-berlin.de>,
"klaus" wrote:
> hello,
labview)? I
> output. any ideas?
> klaus
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,693 Views)
Look at the earlier thread called Labview and soundcards.
markwysong@my-deja.com wrote:
>The only way that I know to do this is to actually take the output of>the
card and route it into a data acquisition card, specifically a sound>and
vibration card. You can then use the standard VIs is LabVIEW to>get and
display the sound card output, as well as the frequency content.>>Mark>>In
article <8tbvoq$mfu8q$1@fu-berlin.de>,> "klaus" wrote:>>
hello,>>>> is it possible to read data from the output of a soundcard (in>labview)?
I>> would like to build a spectrum analyzer that monitors the soundcard's>>
output. any ideas?>>>> klaus>>>> -->>>>>>>Sent via Deja.com http://www.deja.com/>Before
you buy.
(3,692 Views)
klaus wrote:
> hello,
> output. any ideas?
> klaus
die gleiche Frage interessiert mich auch.Falls ich was erfahre
sage ich Dir bescheit.
Tschüss Jürgen
(3,688 Views)
Check out:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&F48CD397F4802D548625683A000BA37A&cat=DF6C376444460910862567E1006CD25F
(3,688 Views)
