read tdms with root / c++ in linux
Hi, even if some time whent by, I am wondering if you got a solution for this topic. I found https://nptdms.readthedocs.io/en/stable/reading.html that's looks quite promising.
Unfortunate still not c++ and only limited writing support. I am looking for a full read/write TDMS solution under Linux.
Greetings rom Switzerland
Message 11 of 13
(330 Views)
libtdms is a C++ cross-platform library for reading .tdms files: https://www.iondev.ro/tdms/
It was tested on Windows with MinGW and Borland 10 C++ compilers, on Linux with gcc and on macOS with clang and gcc compilers.
libtdms is available under two licenses: GPL and commercial.
Ion
Message 12 of 13
(229 Views)
Greetings from Bucharest,
Ion
Message 13 of 13
(228 Views)
