read text file with labview 7 professional
This is my textfile in labview.
how to seperate this data?
Message 11 of 13
(1,002 Views)
Separate
Read from spreadsheet file.  Use space as a delimiter.  Delete the first X lines of the array since that is all header info.
Message 12 of 13
(993 Views)
It looks like the data is separated by spaces. The default separator for the Read From Spreadsheet File is a tab so you just have to change the default to get a 2D array. If you have used a function to get the entire file, extract just the data and pass it to the Spreadsheet String to Array.
Message 13 of 13
(992 Views)
