06-06-2008 02:54 AM
06-06-2008 02:59 AM
Hi hakan,
how do you see that you only read one channel? If i use your test vi, then i can read six channels with it. The text file which you create has also six columns.
Mike
06-06-2008 03:47 AM - edited 06-06-2008 03:50 AM
Hi mike,
when i run the program, it's show me one signal. but now i fixed 2 AI. one loadcell output "AI 2" and other "AO 1" to "AI 1". ( "AI 1" from "AO 0" ) but i can see just one signal. i suppose it's show me signal between two value.
i sent the my screen.
the program is multiplication the AI 1 but it's not perform the AI 2. why?? :s
but ithe program can plus AI 1 and AI 2 with what i want value.
i can save the txt.file what i can see the data.
thanks for everything mike 😉
i hope i could i explain my problem, i'm sorry my english 😞
hakan
06-06-2008 04:13 AM - edited 06-06-2008 04:13 AM
06-06-2008 06:24 AM
hi mike 😉
thank u so much,. i saw the signals.
i'm much obliged to u...
but, i fixed just two input but i saw 3 signals ( third signal is on the "0" ) and The program is multiplication the AI 1 but it's not perform same operation to the AI 2. do u know, why?
i hope i'll solve these problem.
again, thanks for everything...
hakan...
06-06-2008 06:30 AM
Hi hakan,
right click on the "Array to Cluster" function and select "Cluster Size". Change it two the number you need, i think 2. ![]()
Mike
06-06-2008 06:45 AM
06-06-2008 07:04 AM - edited 06-06-2008 07:05 AM
06-06-2008 07:32 AM - edited 06-06-2008 07:38 AM
hi mike ![]()
the program is running very good 😉
the last problem about program,
The program can't save the "coefficent" and "plus" number. can i save this number. i don't want to write it everytime when i open the program
take care
hakan...
