read the AI from 6 channels
hello everybody,
i read AI but just one input sad.gif but i have to read 6 anolog input...
i sent my old and new program.
pls hep me
i need your help...
thanks for everything
hakan...
Message 1 of 9
(3,330 Views)
Hi hakan,
how do you see that you only read one channel? If i use your test vi, then i can read six channels with it. The text file which you create has also six columns.
Mike
Message 2 of 9
(3,327 Views)
Hi mike,
when i run the program, it's show me one signal. but now i fixed 2 AI. one loadcell output "AI 2" and other "AO 1" to "AI 1".  ( "AI 1" from "AO 0"  )     but i can see just one signal. i suppose it's show me signal between two value.
i sent the my screen.
the program is multiplication the AI 1 but it's  not perform the AI 2. why?? :s
but ithe program can plus AI 1 and AI 2  with what i want value.
i can save the txt.file what i can see the data.
thanks for everything mike 😉
i hope i could i explain my problem, i'm sorry my english 😞
hakan
Message Edited by hknmkt on 06-06-2008 03:50 AM
Message 3 of 9
(3,317 Views)
Hi hakan,
sorry that i see it first now, you only write one signal into your chart.
See the attached picture, it shows how you can write to channels to a chart.
Mike
Message Edited by MikeS81 on 06-06-2008 11:13 AM
Message 4 of 9
(3,307 Views)
hi mike  😉
thank u so much,. i saw the signals.
i'm much obliged to u...
but, i fixed just two input but i saw 3 signals ( third signal is on the "0" ) and  The program is multiplication the AI 1 but it's not perform same operation to the AI 2. do u know, why?
i hope i'll solve these problem.
again,  thanks for everything...
hakan...
Message 5 of 9
(3,296 Views)
Hi hakan,
right click on the "Array to Cluster" function and select "Cluster Size". Change it two the number you need, i think 2. Smiley Wink
Mike
Message 6 of 9
(3,292 Views)
thanks dude,
u know that, u're perfect 😉
but i couldn't solve the multiplication problem...
The program is multiplication the AI 1 but it's not perform same operation to the AI 2.   Do u know, why?
again thanks mike 😉
hakan
Message 7 of 9
(3,285 Views)
Hi hakan,
no i don´t know why it not work. Are you sure about it? Normally it should work.
Mike
Message Edited by MikeS81 on 06-06-2008 02:05 PM
Message 8 of 9
(3,269 Views)
hi mike
the program is running very good 😉
the last problem about program,
The program can't save the "coefficent" and "plus" number. can i save this number. i don't want to write it everytime when  i open the program
take care
hakan...
Message Edited by hknmkt on 06-06-2008 07:38 AM
Message 9 of 9
(3,259 Views)
