read trace function doesn´t give data when start timestamp is later than last value change of the variable
The read trace function doesn´t give me the datas of one variable when the start timestamp is later than last value change of the variable and this variable is not in the same PC. If I use the same read trace in the PC where is the data base the is no problem. If the start timestamp is before the last value change of the variable the is no problem too.
Thank you
Message 1 of 1
(2,461 Views)
