read write data
Hi ,
I am reading string array from one txt file and now i want to compare the first character of the each element of this array and read corresponding line.How can i do it?i have attached some picture so you can understand easily.
Message 1 of 9
(4,596 Views)
use string subset, then compare...
Message 2 of 9
(4,584 Views)
Thanks for reply
You did not get my question actually in above picture you can see first character is like
0                           o.4755  21
0                           0.4766  22
1                           0,4822  36
1                           0,4877  23
This is my index for measurement.now for another measurement i want to read this first character(index no) and select corresponding row
Message 3 of 9
(4,573 Views)
0
0
1
1
this first character itself is index number for my measurement so i want to search this index no and read corresponding line like here i want measured value for no 1
Message 4 of 9
(4,552 Views)
@royal1 wrote:
0
0
1
1
Are you trying to read all of the lines with an index of 1?  If not, which one do you read?
Message 5 of 9
(4,545 Views)
yes exactly i need all line with character 1(index 1)
Message 6 of 9
(4,540 Views)
Accepted by royal1
Hi, I guess u are looking for multiple search result as shown.
If not replace for loop with while loop with "stop"  criterion either "i => array size" or search criteria gets any match
Message 7 of 9
(4,538 Views)
Yes my friend exactly i want this one Smiley HappySmiley HappySmiley HappySmiley HappySmiley Very HappySmiley Very Happy
Thank you very much
Message 8 of 9
(4,533 Views)
take a look at this, I think this one is better..
Message 9 of 9
(4,529 Views)
