reading 64-bit integers from file
Hello dlbuhl,
first: I added a "Reverse 1D array" to get your example number (byte order problem...).
2nd: I made the radix visible. Now you can change the display more easily. (right click on numerical indicator->visble items, or: roght click->Format&Precision).
Message 11 of 12
(712 Views)
Thank you all VERY MUCH! That is exactly what I needed.
Message 12 of 12
(564 Views)
