reading from file
I was wondering if someone could help here. I have to read from a file line by line such that each time the word FAIL is found,
output each listed character follow by a tab and the corresponding number. For each missing character here give it the value found after FAIL.
for example from the attached file: in the first line I have FAIL 100 so I will output:
e          102
i            699
o          717
and I have to add the missing character of the alphabet that are not here and give them the value after FAIL
so, I will have
e          102
i            699
o          717
a          100
b         100
c          100
d         100
f         100
g          100
h         100
j          100
k          100
l          100
Message 1 of 20
(4,803 Views)
Is this what you need? You didn't specify what the output should be, so I assumed an array would be fine.
Note how this works. It uses regular expressions, which are pretty powerful. I look for the FAIL line with the first Match Regular Expression, and then I take everything after that match. Next, I look for the next FAIL line, and I take everything before that match. That gives the letters and numbers after the first FAIL line.
Then, wash, rinse and repeat as neeeded. Oh, well, skip the wash and rinse part, just repeat until the second one gives -1 for offset past match!
Message 2 of 20
(4,770 Views)
Not really, But good indication. I need something like this but all the missing characters of the alphabet should also be listed and should have the value of the number after FAIL.
So in this case, let consider spot 1 of this output array, we have
e 102
i 699
o 717
but the rest of the alphabet is missing, a, b, c, d,f,g, h, j... are missing. And because they are not listed on the original list so I have to give them the value of FAIL ( the number coming after FAIL, which is 100 for this spot
so,
I will give them the value of 100
spot 1 will look like this:
e 102
i 699
o 717
a 100
b 100
c 100
d 100
f 100
g 100
spot2 will look like this:
c 103
f 674
t 512
a 147
b 147
d 147
e 147
Thanks for your help.
Message 3 of 20
(4,753 Views)
That should be simple for you to add. Use the "whole match" output of the first Regular Expression primitive and wire that into the "input string" of a third Regular Expression primitive with the regular expression rule "Face [0-9]+  FAIL  ". The "after match" of the third Regular Expression will be the number (error code?) you are interested in.
Then, write a little code to find out which letters you are missing in each iteration of the loop. Concatenate those missing letters with the number from the third Regular Expression primitive above. Concatenate that string with what is in each array element now and you'll have what you are looking for.
Message 4 of 20
(4,738 Views)
Easy to say but seems to take me a lot of time.
I don't get this ..."and wire that into the "input string" of a third Regular Expression primitive with the regular expression rule "Face [0-9]+  FAIL  " . Can you clarify a bit?
Message 5 of 20
(4,735 Views)
Oh, sorry about that!! I expanded on the original VI that I sent to you, but I didn't post it.
This VI gets you what was originally posted, plus the "third Regular Expression primitive" that gets the error code for the rest of the alphabet.
I attached the VI that gets the error code for the rest of the alphabet and a loop that finds what letters you have, so you know which ones you have to get. I bet you can get the rest of the alphabet and concatenate it with the error code that isn't in each array element Smiley Wink
Message 6 of 20
(4,724 Views)
Thanks, I will trying.
Message 7 of 20
(4,713 Views)
Good. Give it a try and if you get stuck I'll give you some hints!
Message 8 of 20
(4,710 Views)
I definetly need some help here to get this done as we need it today. This is what I am trying but IAM REALLY STACK.
More help will help.
Message 9 of 20
(4,705 Views)
I have LV2009, can you save for that?
Message 10 of 20
(4,698 Views)
