strange dll problem
Hi @ all,
i have a strange problem. I have a dll working under LV8.5. Now i have switched the version to LV2010. I can sometimes load my vi's with the dll functions inside and sometimes not. If i create a new vi and insert the call library function node inside of it to configure the first function call then it works. If i then store the vi and reload it without to close LabVIEW completly, then i get the error "error while loading the x.dll". If i close LabVIEW comletly, then i can reopen it again. As i said, with LabVIEW 8.5 it works well.
Can someone please give me some hints? What can i do?
Unfortunatly i can't upload the dll.
I'm working on XP.
Best regards
Egon
(2,770 Views)
Hi Egon,
Does the error have an error number? If you can give me the error number I have a starting point to do further research for you in the NI database.
The following website does not exactly meet your error message but might show new ideas how to search for the cause of the error
http://digital.ni.com/public.nsf/allkb/7253D2F0D91F68058625752F005AB672?OpenDocument
Stefan
Stefan Egeler
Application Engineer
NI Germany
(2,739 Views)
