reading from serial port
LV = LabVIEW
environment = doing it from within LabVIEW as opposed to somewhere else (e.g. MAX, LabWindows, ....)
Message 31 of 36
(1,970 Views)
@Ravens Fan wrote:
LV = LabVIEW
I'm probably wrong, but i count MAX to LV environment as it's a requirement to use the ports in LV, just more on the ... driver level. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 32 of 36
(1,957 Views)
HI again;
I could be able to run two ports simultaneously and I received data from both ports!
even if any program is not running in labview, or I just click to run the program my computer re-started automatically, This happened several times! I scanned the computer there is no any virus, and also if this specific Labview program hasn't been running, this auto restarting never happened!,
I am sure this crash is because of labview program.
Do you have any idea?
P.S. I am connecting two Bluetooths (with com port) to communicate with Laview program,every time I want to run the program I should restart Labview to recognize the ports.
Cheers;
Message 33 of 36
(1,917 Views)
Does it show any error messages before restarting?  Is it blue screening?
Message 34 of 36
(1,912 Views)
No at all, nothing. It is the same as some one press the restart button!
I checked with other Labview program, I didn't see any wrong. Just crach in this specific one.
Message 35 of 36
(1,905 Views)
By the way, this happened just with Bluetooth mates. By using wire to pc, it works fine!
Message 36 of 36
(1,882 Views)
