reading pattern from a text file not showing properly
I am trying to read an array from a .txt file ( which is a 650x350 pattern) and then display that.
Attached please find the files.
The displayed pattern is compressed compared to if you open in it matlab (see "rep.png" for understanding).
Please help me display a clear pattern through vi named disp.vi?
regards
(2,830 Views)
First,  Matlab arrays are [Col, Row]  LabVIEW arrays are [Row, Col] so a transpose is needed there.  Next your file contains U8 data of 2 rows and 227500 columns.  which row are you interested in for your 350x650 display?
(2,810 Views)
Ok thank you for pointing out that.
The data is arranged in rows. So you can pick up any row and reshape it into 650x350 array, and then the problem comes as the displayed pattern is very compressed
(2,805 Views)
Accepted by jonty_roads
Reshape it to 350x650 and use BLUE wires
(2,802 Views)
Can you please share your modified version.
Kind regards
(2,788 Views)
attached in 2016
(2,780 Views)
(2,723 Views)
