reading the folder
HI
thank you for yur reply ,
yes it's what I want ,, so can you help me to find a solution fr my problem .
Message 11 of 32
(1,610 Views)
If you want drop down menus, then I recommend you use ComboBoxes (in the String Control palette) for your controls.  You can populate them with the Strings[] property.  You can get the list of available strings using the List Path.  When going this route, you will also want to use an Event Structure in order to detect when a value want changed and you can then update the other ComboBoxes.
Message 12 of 32
(1,603 Views)
HI
actualy I didn't undrestand yu very well can you code it in labview
thank you
Message 13 of 32
(1,601 Views)
Here's something to get you started.
Message 14 of 32
(1,594 Views)
HI
actualy I cant find the property node strings [] ,can you help me to get it and what's the type of month and year icon that you used
thank's
Message 15 of 32
(1,577 Views)
Just create a property node of the ComboBox.  One of the available properties is Strings[].  You may have to scroll down in the list, but it is there on the top menu.
@ichrakk wrote: and what's the type of month and year icon that you used
They are just normal control terminals with the View As Icon turned off.
Message 16 of 32
(1,563 Views)
HI
can you have a look in my vi file and tell me what's wrong ,why it can read the text file
and thank you
Message 17 of 32
(1,547 Views)
Do you get an error?
Why do so many controls have missing labels, or labels that start with spaces?
When you get to using the final "txt" string that you convert to a path, what does it look like?  (i.e. put in an indicator)  You seem to be drilling down through directories, but you don't seem to be using the path of directories you have to build a full file path.  You seem to be just using a filename.
Message 18 of 32
(1,542 Views)
HI
so how can I use the path to open that text file pleae.
thank you
Message 19 of 32
(1,531 Views)
Use the Build Path function, actually a series of them, to create the full path that includes all the names of sub folders you picked out along the way.
Message 20 of 32
(1,527 Views)
