real time clock display on labview
hey guy , im doing a project on labview that i want to just make prettier for the lecturer
is there a way to add a clock to the front panel that will tell the time , ideally in h:m:s format
all help welcome
thanks
kevinSmiley Happy
(11,450 Views)
This is a VERY basic question.  I realize you're new to LabVIEW but please do even just a little research before falling back on a forum to get answers. Smiley Wink
Drop a time stamp indicator down and wire the Get Date/Time VI to it.  That's it.  If you don't want to see the date right-click and go to the Display Format properties.  You can also resize and color it to make it pretty.  Have fun.
(11,432 Views)
Add a "Get Date/Time in Seconds" function from the functions pallete along with any neccesary format modifiers (see attached).
(11,425 Views)
Hi Kevin,
Adding to the great answers above: If you wish to create an analog clock face for your front panel you can work through the following example code:
https://forums.ni.com/t5/Example-Code/Creating-an-Analogue-Clock-Using-Gauges/ta-p/3511908
It is also noteworthy that within the LabVIEW community "Real Time" usually refers to a deterministic operating system (RTOS) or code running on an RTOS. More information can be found below
https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(11,383 Views)
Accepted by topic author kevinbarry92
Pretty cool Tim.  Here's an old one I had floating around that has a neat wooden face and the code is really simple.   It's in LV10.
(11,356 Views)
Oh boy does this take me back.  Time to post one of my first LabVIEW programs. Clock Program
(11,330 Views)
wooden clock looks awesomem, thanks thats exactly the kind of stuff i was looki ng for , thanks guys
(11,282 Views)
