real time destop pc
hi ...
I am tryin to convert a desktop pc to use labview real time .....but when i boot my pc using usb (desktop utility usb real time already created using MAX in usb) it give me the error "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
any suggestions?
Regards
Message 1 of 15
(4,925 Views)
Hope this will give you a solution. Always remember to do a search in the forum. Most of the problems were solved. Post if you had still problems.
Mathan
Message 2 of 15
(4,922 Views)
hi ...thnx it was solved but now when i select the option "boot using software installled on the hard disk ......it gives me the error unable to configure primary network device ....
i have xp installed on the harddisk an labview 8.2 ...do i need to format the whole hard disk before convertng it to a real time target??
Regards
Message 3 of 15
(4,920 Views)
Again search.
Post back your findings.
Mathan
Message 4 of 15
(4,913 Views)
similary if i select the option "evaluate system" it gives the error
"system error kernel.446610 : LFS Error : Not a DOS disk: pc_dskinit "
Regards
Message 5 of 15
(4,912 Views)
Discussion on this error topic
Message 6 of 15
(4,909 Views)
thnx i m readin it rite now ...will let u know
Regards
Message 7 of 15
(4,907 Views)
i have read the disscusions they all say that the ethernet drivers are not correctly installed ...i have installed them again they seem to be working ok in XP but when i run the evaluate test from the usb disk utility it gives only one error system state: IP stack Confriguration Error
Regards
Message 8 of 15
(4,894 Views)
Reinstalling the XP driver will not help in LV RT. LV RT has its own drivers, but only a limited set of ethernet chipsets is supported. See requirements document here.
By the way, what file system do you use? NTFS is not supported by LV RT. You will have to use FAT32. Again, check the requirements document.
Hope this helps,
Daniel
Message 9 of 15
(4,888 Views)
i just keep getting this " Broadcom 57xx Ethernet  "... error ..it gets intialized but " no devices found " ..why is that ..???
Loading Ethernet Drivers:
 Intel 8255x Ethernet initialized successfully
 Intel 8254x Ethernet initialized successfully
 Broadcom 57xx Ethernet   initialized successfully
Finding devices for Ethernet drivers:
 Error! No supported network devices found. A network adapter with
 a supported Ethernet chipset is required
Starting up IP Stack.... failed.
 Unable to configure the primary network device
System state: IP Stack Configuration Error
Regards
Message 10 of 15
(4,863 Views)
