rearranging data in an array
I am having an input array in which i am reading data from csv file, i want to rearrange the data, so as to present it in presentable format, i have tried some operations but not getting exactly how to do.
below i am attaching the vi which contains the input array and the expected data.
Message 1 of 26
(5,626 Views)
Hello Ritu,
Here is one of the ways to do what you have described.
Let me know if this helps.
Chinmay
Chinmay Anand Misra
CLD
Technical Marketing Engineer
NI IndRA
Message 2 of 26
(5,600 Views)
Hi Ritu,
how about this:
Alex
Message 3 of 26
(5,597 Views)
Hi Chinmay_NI
thankyou for your solution,
the output is coming as expected but one issue is that I cannot give Vbat and other parameters as constant in search 1D array as these names may vary depending on the test, and second thing is as i am reading the data from file in input array we might have verion number and other basic info again in program, i eill try to sort out these issues.
Thankyou
Message 4 of 26
(5,590 Views)
Chinmay_NI
I am getting one problem in the program, the solution you posted is working fine for me, but the problem is that i am having larger set of data in input array in which i am having version number and other things more than once and Vbat and othe things are also not constant i tried to fix these issues but stil not getting the result as expected, if you can help me i n sorting out this one issue
Thankyou
below i am attaching program,
Message 5 of 26
(5,551 Views)
This is how i am trying to modify the result but not getting the correct output, i might be following wrong approach, please help me in this data formatting.
Message 6 of 26
(5,530 Views)
Can you upload the code 2011
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 7 of 26
(5,528 Views)
Thankyou Ranjeet_Singh for the reply,
here i am attaching the code in LV 2011
Message 8 of 26
(5,525 Views)
Hey Ritu,
                   Can you let me know the expected input and expected output?
thank
--Ranjeet
Message 9 of 26
(5,518 Views)
expected input i have kept as constant there in block diagram the array for expected output is alco there with the name expected data
Message 10 of 26
(5,513 Views)
