rearranging data in an array
I got the input but didnt get expected output
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 26
(2,028 Views)
there are two arrays on the fromt panel out of which one is expected data which is same as  expected output anyways i am attaching the image below of the array containing expected data
Message 12 of 26
(2,025 Views)
i have imlemented some changes to make the program geneic for parameter values so that we don need to givee then as constants, but still not getting the correct output , belowi am attaching the vi with the output coming and the expected output.
Message 13 of 26
(1,965 Views)
someone please help me in this data formatting i am stucked up not getting how to do....
Message 14 of 26
(1,950 Views)
2 thing,
1. Will the pattern you upload which you reading from csv file is fixed.
2. Upload in 2011
--Ranjeet
Message 15 of 26
(1,946 Views)
yes pattern is fixed but the values are not fixed like Vbat, VGG these are parameter values which depends upon user input these could be anyone so we cannot make a program specifically for these valyues
below i am attaching the vi with the input and the correct output, this vi is working fine for the 3 values but the problem is that i cant keep these4 values as constants and i tried to make them variable also by taking out Vbat andall the parametrs that i am using fromn the array but not able to implement propery and data was not coming correct
Message 16 of 26
(1,945 Views)
Can you add 4th value in array.
--Ranjeet
Message 17 of 26
(1,939 Views)
sorry i didn't get you which 4th value you are asking
Message 18 of 26
(1,936 Views)
4 values you mentioned. So 4th value
--Ranjeet
Message 19 of 26
(1,933 Views)
by 4 values i mean that like here i am using just 3 input parameters Vbat, Vout, and Ibat ( VGG in volt test i have added just now ) so this program works fine if these parameters are always same but the problem is this that thier values may change depeding on the input the user will give and second thing it is not compulsory that every test will have the same number of parameter, e.g freq.  test might have only 2 parameters(Vbat & Ibat) and volt test can have more than 2 (Vbat, Ibat, VGG, Vout) like this.
Message 20 of 26
(1,930 Views)
