recording multi channel with PXI 5162 + Delay time
I am currently using Labview to develop a program to acquire NI PXI 5162 oscilloscope curves and save them in an array (time + amplitude).
I find it difficult to acquire the two curves (two different chains) and trigger on one of the two.
1- Can you help me to have an example code of acquisition of two curves and to record the data in a table?
On the NI PXI 5162 test interface (on MAX), there is the delay time function which calculates the time between two edges of two curves. I can't find this function in the NI SCOPE library.
2- Can you explain to me how to implement it?
Thank you in advance for your responsiveness.
(1,318 Views)
(1,245 Views)
