redpitaya. error 63
I have been trying to connect my Redpitaya in order to do the example "Blink" from the RedPitaya library. However, when I run the example, every time I've tried it it has shown the same error on the screen : error 63 The network connection was refused by the server.
I have connected it by ethernet, and wrote the IP in Tools->options->IV server -> machine access, as well as selected the TCP/IP box.
Did anyone have the same problem, and how could it be  solved ?
Thanks in advance.
(4,529 Views)
Accepted by topic author lucialucilu
Did you start the SCPI server on the instrument?
(see e.g. here)
(4,505 Views)
that was the problem, I forgot to do it. now, it works fine.
Thanks!
(4,365 Views)
