reduce the view of block diagram in order to organize it
i don't know if it is possible but i want to reduce the view of the block diagram like in MS word (60% or 80%) in order to oragnize all the blocks...to align them,.....
How can i do this? Now, i can only see few blocks and my Vi is so big....
Larson
Message 1 of 20
(6,138 Views)
Hmm, what i do is go to a higher resolution setting of the screen area in windows to view more block diagram area on the screen
I have not come across such a feature for reducing size of Block diagram in LabVIEW.
To keep the block diagram layout compact, i usually convert sections of block diagrams as sub VI's.
Hope this helps
Regards
Dev
Message 2 of 20
(6,133 Views)
Hii Larson,
       Another thing you can do to compress your block diagram is, you can arrange it with the help of Navigation window, which gives you total idea of the vi and outlooking that you can arrange your whole block diagram, another thing is you also can maximize the navigation window, which gives you an outlook of your block diagram(but not clear Smiley Wink).
Nishant
Message 3 of 20
(6,131 Views)
Plus on your tool-bar, you will find two windows
  • align objects
  • distribute objects
Use these for making the alignment, arrrangement of your block diagram functions quicker and easier
Message 4 of 20
(6,076 Views)
I don't know what is navigation window?? the block diagram window??
Can you explain me, please?
Thanks!
Larson
Message 5 of 20
(6,124 Views)
In your block diagram/front panel, go to 'windows' in  menu-bar and select 'show navigation window'
Message 6 of 20
(6,121 Views)
Thanks, Dev
          Thanks for explaining him about navigation window and i think that is the good solution witht the align and distribute objects, becoz of which he can mange his block diagram, and also can take the snapshot of it.
Nishant
Message 7 of 20
(6,068 Views)
Thanks Nishant,
So, How was your kite flying festival in Gujarath?
Message 8 of 20
(6,062 Views)
Sorry...but i don't find it.
I've attached two images of my window menu.
I'm using labview 7.0..i don't know if there are more possibilties in labview 7.1 (i use in my home)
Thanks!!!
Bye
Message 9 of 20
(6,108 Views)
Ok, look at this PIC
Message 10 of 20
(6,104 Views)
