relate mouse click position to points on graphs
I am working with labview 7, on windows XP. I am trying to relate between a mouse click on a waveform chart to a point on the chart. All I managed to do so far is relate with a cursor, but the cursor has to be dragged and I want the user just to click on the graph. Is that possible?
(2,945 Views)
Hi ye
Look at this thread: http://forums.ni.com/ni/board/message?board.id=170&message.id=100018
You will have to map mouse coordenates to graph ones.
The Clily Charlie vis can instructyou about it.
Greetings
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,935 Views)
Thanks, but I am working with labview 7, so labview 7.1 vi's wont open up...
can you explain the principle please (or refer me to version 7 vi's) ?
(2,932 Views)
Hello
Attached is a labview example lv 7.0 about how to map cursor coordinates to graph units.
Perhaps Chilly Charly can post his vis en 7.0
Greetings
Alipio
(2,928 Views)
Thanks alot, I will try it and let you know how it goes...
(2,926 Views)
