remote GPIB
Good Day, Ladies and Gentlemen.  I am trying to read a TRAK Microwave GPS clock.  The clock is a GPIB instrument attached to a 488 card in a remote PC.  The VISA address for this device is GPIB0::7::INSTR.  I want to issue the command "RQLT\r", but have not been successful.  See attached screen shot.
I suspect the problem is the instrument address.  I have no problem accessing the clock using Vee Pro.  I thought the instrument may not yet be registered with LabVIEW, but cannot find any app to pull this instrument in.
(3,610 Views)
Accepted by topic author RT56
If you are going to use a VISA resource name, you have to use VISA functions. If you are going to use GPIB functions, you have to use a GPIB address (i.e. '5'). I would recomend using VISA. You will also need to enable remote VISA on the other pc.
(3,607 Views)
For remote visa, you need to provide a fully qualified path to the instrument.
I haven't done this for a long time, but it should be the name or address of the computer hosting the gpib board followed by the board number, address and type:
something like:
visa://192.186.1.23/GPIB0::7::INSTR
You also have to have the NI-VISA Remote Server running on the computer hosting the GPIB card.
See this Knowledgebase entry: Remote Instrument Control with NI-VISA
(3,598 Views)
Dennis and Phillip, thanks for the feedback.  I have changed over to VISA protocols.  Phillip, thanks for the resource name format.  That was a piece of information that I was looking for.
Having taken this into account, I was successful in reading the clock once, but have not been able to duplicate the result.  Interestingly enough, the visa://[ip address]/GPIB0::7::INSTR results in an execution error that complains that the resource name cannot be parsed.  If I use the GPIB0::7::INSTR, or the VISA alias, the VI runs with an instrument error.
I am running Agilent VISA.  LabVIEW is configured to look at this resource for VISA instrument connections.
I'm stuck now.
(3,584 Views)
