04-25-2011 11:31 AM
Good Day, Ladies and Gentlemen. I am trying to read a TRAK Microwave GPS clock. The clock is a GPIB instrument attached to a 488 card in a remote PC. The VISA address for this device is GPIB0::7::INSTR. I want to issue the command "RQLT\r", but have not been successful. See attached screen shot.
I suspect the problem is the instrument address. I have no problem accessing the clock using Vee Pro. I thought the instrument may not yet be registered with LabVIEW, but cannot find any app to pull this instrument in.
Solved! Go to Solution.
04-25-2011 11:47 AM
If you are going to use a VISA resource name, you have to use VISA functions. If you are going to use GPIB functions, you have to use a GPIB address (i.e. '5'). I would recomend using VISA. You will also need to enable remote VISA on the other pc.
04-25-2011
12:24 PM
- last edited on
08-22-2026
02:43 PM
by
Content Cleaner
For remote visa, you need to provide a fully qualified path to the instrument.
I haven't done this for a long time, but it should be the name or address of the computer hosting the gpib board followed by the board number, address and type:
something like:
visa://192.186.1.23/GPIB0::7::INSTR
You also have to have the NI-VISA Remote Server running on the computer hosting the GPIB card.
See this Knowledgebase entry: Remote Instrument Control with NI-VISA [link removed; article no longer available]
04-25-2011 01:30 PM
Dennis and Phillip, thanks for the feedback. I have changed over to VISA protocols. Phillip, thanks for the resource name format. That was a piece of information that I was looking for.
Having taken this into account, I was successful in reading the clock once, but have not been able to duplicate the result. Interestingly enough, the visa://[ip address]/GPIB0::7::INSTR results in an execution error that complains that the resource name cannot be parsed. If I use the GPIB0::7::INSTR, or the VISA alias, the VI runs with an instrument error.
I am running Agilent VISA. LabVIEW is configured to look at this resource for VISA instrument connections.
I'm stuck now.
