remote control
I have to connect two laptops distants from about 1 km.
I've got just a phone line to communicate.The first computer must acquire vibrations measurements and the second one must pilot the first one to start and stop acquistion.
Could you show me how to proceed modem communication whith Labview, i have not clear idea about that.
Best regards
(2,655 Views)
Paganini,
It would not be to hard to do. You would set up one modem to automatically answer. On the other side you instruct the modem to dial using AT commands. Once the connection has been established then you can use it as if it were a regular serial connection. The following tutorial describes how this can be done between a FP-2000 module and a host computer, but the idea would be the same between two computers.
http://zone.ni.com/devzone/conceptd.nsf/webmain/4B5DC1F4481A33F286256B4A007D0216?OpenDocument
Carl L
(2,655 Views)
