remotely indicate cursor position
I've attached an exaple where i want to indicate my cursor x position on my remote VI, but it doesn't seem to work? All other dynamically registered events do work... but the value change on a number doesn't?
Thijs
(2,803 Views)
Accepted by ThijsBoeree
I have looked in your code and I found the problem.
The problem is that a programmatically value change will not effect a event. So you have to change the property DigNum to --> Value (signaling) --> See print screen bellow.
Please let me know if you have further questions
Corné Westeneng
Applications Engineer
NI-Netherlands
(2,769 Views)
Thanks!! It works like a charm!
Thijs
(2,763 Views)
