remove default labview icon
I built a dll in LabVIEW which is called by a C# application.
When loading windows shows a task in the taskbar with the default labview icon.
This is not wanted.
A solution would be to customize the icon (like possible with executables) or remove the task from the taskbar while the dll is running.
Is this an option?
Kim
(5,503 Views)
did you do a search on this forum? there are plenty of posts
(5,470 Views)
Careful there, apok.  The OP already knows about changing the icon for an EXE.  They are asking about for a DLL.
(5,456 Views)
i better go get checked for A.D.D.  Smiley Indifferent
(5,453 Views)
Accepted by KimT
This thread looks similar.
Have you tried Resource Hacker?
(quote: It is used to modify program or operating system elements such as icons by extracting resources from executable program (.exe), program extension (.dll), and resource (.res) files.)
(5,448 Views)
thanks for the tip.
But this isn't a solution for me.
You have to select a bitmap to change the icon.
There is no image available in my dll.
I guess I have to change the icon of the runtime engine, but I can't find this either.
(5,387 Views)
I edited the lvrt.dll and now it is changed.
It will be changed for all applications, not really what I wanted, but good enough,
(5,378 Views)
