remove runtime 7.1.1 and install runtime 7.1
My system has Labview 7.1 and I also installe 8.5 (so both are on my system) and they both seem to work.  When I load an application that build and distributed with Labview 7.1 it doesn't run; error= "Executable version (7.1.1) doesn't match resource file (7.1).  Check your configuration."  I go to add/remove programs ni software and see that Run-time 7.1.1 is installed.  I try installing Run-time 7.1 and get "Installation aborted.  A higher version of this product is already installed."  If I try to uninstall Run-time 7.1 using the add/remove program tool, I get: "The following product(s) could not be removed.  The following require the above product(s). NI LabVIEW 7.1", (and 15 other NI programs).  I really, really, don't want to have to remove all of them, and then reinstall.
What I want to be able to do is simply either have two version of the runtime or delete 7.1.1 and replace it with 7.1.
Any ideas?
John G.
Massachusetts.
John Gig
(2,821 Views)
Hi John
This is a known problem. See the knowledge base article here.
All you have to do is repair the existing 7.1.1 run-time installation.
Hope this helps
Daniel
(2,818 Views)
Daniel, thanks!  That looks like it'll do the trick.  I've got to wait to get the 8.5DVD back so I can give it a try.  I'll let you know.
John
John Gig
(2,811 Views)
