remove spaces from string
Altenbach,
47 minutes?  You must eat lunch at 11:00 Smiley Very Happy  Very nice solution.
Message Edited by lmtis on 02-13-2008 12:10 PM
Jim
LV 2020
Message 11 of 19
(4,002 Views)
THANK YOU!!!!
Message 12 of 19
(3,981 Views)
The attached is straightforward way to get rid of all spaces in a string.....Don
Message 13 of 19
(3,889 Views)
Using "delete from array" in a loop could get expensive with large inputs because the array in the shift register requires a new allocation in memory for each space found. I would not recommend that. Try to find an "in-place" solution. 🙂
Alternatively, just do the following... 😮
Message Edited by altenbach on 01-21-2009 03:19 PM
Message 14 of 19
(3,870 Views)
I actually tried this earlier but I tried to use a string constant with a space in it as the string to replace instead of using the space constant.
Now I now (or know again) about the space constant.
Indeed this is a better solution.
Don
Message 15 of 19
(3,839 Views)
That should work equally well, though. 🙂
Message 16 of 19
(3,834 Views)
Actually you are right, I think I used the string constant without putting a space in it!
Message Edited by DonRoth on 01-22-2009 10:37 AM
Message 17 of 19
(3,831 Views)
Yes, that's probably one of the more confusing behaviors: An empty string constant gets shorter (horizontally) when you type a "space" in it using a proportional font. 😉
I would typically set the display to \-codes to make it more readable.
Message 18 of 19
(3,820 Views)
Had I set to 'codes display', I would have discovered my mistake so that is always a good check when dealing with delimiters and such.
Message 19 of 19
(3,816 Views)
