remove threshold imaq image
I´m using labview 2011 with development vision.
I'm working with some images and created a function to enable and disable the image THRESHOLD.
I can open the original image and activate the threshold but can not get the image back to the original when I disable the threshold.
Does anyone know how I could activate it and deactivate it with a button?
Thank You.
(5,013 Views)
1. Try to make copy of your image (with IMAQ Copy) then apply Threshold to copy.
2. Show your code here.
(5,004 Views)
Here is the code.
Thank You.
(5,002 Views)
Accepted by topic author eliel
The IMAQ Images transfreed by references, not by values. After thresholding you have no original image.
Use design pattern like this:
See attached VI too.
Andrey.
(4,997 Views)
Hello..
Thank You very much, this is the best solution...
But...i want know how can i put a slide for change the range of the threshold?
and how can i do that ..automaticaly.....whan i change the value of the range automatically change in the image.?
I'll give Kudos for you and accept your answer as solution..ok...THANKS..
(4,989 Views)
Hi
Place a slide to control either the min or max value of your threshold range and use the slider value change event in your event structure: like this
Hope this helps
Regards
(4,331 Views)
