repeat a repetitive value for a given time
Hi to all: I have this VI and its respective invocked .txt files. You select one of these files and it spreads an array with a number sequence, the second part takes value by value of that array to show each one as a integer number for 1.5s.
I have two questions:
1. What can I do to to repeat that number sequence in the integer number (called "valor" in the VI) form for a given time (40 or 45 min for example)??
2. How can I get every value of "valor" out of the for loop in real time?? (to show "valor" out of the for loop in real time)
Thank you! Smiley Happy
Carlos Ignacio Sarmiento
Electronic Engineer
(Ciudad Madero Technological Institute)
Laboratory of Bioelectronics, Biohospital Engineering Departament
National Institute of Neurology and Neurosurgery "Manuel Velasco Suárez" (Mexico City)
(3,054 Views)
these are the files:
Electronic Engineer
(3,053 Views)
I apologize, this is the VI
Electronic Engineer
(3,042 Views)
it is hard to make any sense about what you are saying? according to your block diagram...you are getting your array value and converting it to a U32 then convertin again to a string, then again to a dbl and a I32...very confusing.
you can do this with a simple while loop, shift regs. and timer...i try and stay away from flat sequence programming as you cannot transition as well as a state machine architecture.
(3,024 Views)
try not to use the wait(ms) function for your programming timer (CLD requirement). Elapsed Time Vi can be your friend...
Spoiler
(3,007 Views)
I was reading about auto indexing propiety and I found to do it easier than the first one (without DBL or I32 converters), but it is still the same problem... How to repeat all the sequence in an easy way with this?
Electronic Engineer
(2,991 Views)
the problem is that the "for loop" will run dependent on the Ncount or array size, which ever is smaller. Use of a "while loop" is repeatable...
a different take using Quotient & Remainder...
Spoiler
(2,973 Views)
