replacing xml child
I am having troubles replacing xml child inside XML document (below). In order to modify the xml node value, do I really need to replace the child  or there is a way to modify the xml node value ?
(4,483 Views)
Accepted by dotan
It appears that you are actually just trying to change the attribute of a node. If so, you can simply get the reference for the attribute and set its value, as shown in the attached example.
(4,470 Views)
More importantly, you can't create an element using its full XPath. The Tag Name of an element is precisely the text inside the < and >, so you tried to create an element that looked like </TimerScript/Sch...> which is probably not what you wanted. I don't think it's legal XML either.
What you needed to do was to create an element with the Tag Name of Delay, then get a reference to /TimerScript/.../CAM60 , then tell CAM60 to add the new Delay element as a child.
I know this is long dead, but someone else may come across it sometime and wonder.
~Chris
(4,078 Views)
