reset counter
I can not find a way to reset an M-series counter back to zero when using it as a simple event counter using LabVIEW and NI-DAQmx.  I am using a PXI-6229 and LabVIEW 8.5.1.  Can anyone suggest a way?
Steve
(7,619 Views)
Accepted by wa5ycg
Here is an example if stop/restart the task is an acceptable solution.
Message Edité par JB le 25-03-2010 02:34 PM
(7,607 Views)
Software solution :
Write the current value of the counter to a shift register of the while loop and then substract it from the new values.
(7,603 Views)
this might work ...
use DAQmx configure channel property node
Counter Input
    Count Edges
           Initial Count
set Initial Count to 0
not sure if you can do this while the task is running, you might need to stop the task / reset the count / restart task
(7,601 Views)
Unfortunately this property is not allowed while the task is running.
Reset is superfluous if stop/restart because the counter will anyway restart at the initial count.
(7,594 Views)
